MG F/TF Fuse & Relay Listing
I noticed there is no thread with information regarding fuse listing and I think it could be useful to forum members. In order to have full information on one place I added listings for TF 2003 onwards below.
I can not create nice tables by using only appropriate fonts, so I decided to use pictures as you can see below. I hope it will be useful to you.
The majority of the fuses are mounted in three fuse boxes:
- Under bonnet fuse box - attached to the LH inner front wing
- Passenger compartment fuse box - installed behind a fuse box closing panel on the driver’s side of the fascia;
- Satellite fuse box attached to the side of the passenger compartment fuse box.
In addition to the fuse boxes, in-line fuses are installed:
- Near the under bonnet fuse box, for the Electric Power Assisted Steering (EPAS) system.
- Behind the LH side trim of the luggage compartment, for the Electro Mechanical Constantly Variable Transmission (EM-CVT), where fitted.
- On the side of the passenger compartment fuse box, for the SRS system.
- Behined driver side of facia, fuse for alternator
FUSE COLORS
UNDER BONNET FUSE BOX
PASSANGER COMPARTMENT AND SATELLITE FUSE BOXES
(RHD is shown, while LHD is simmilar)
EM-CVT FUSE
ALTERNATOR FUSE (MGF 2001 Model Year and after)
ADDITIONAL RELAYS
Source : http://forums.mg-rover.org/mgf-mgtf-spo ... ng-487819/" onclick="window.open(this.href);return false;
made By Roverlike
Re: MG F/TF Fuse & Relay Listing
________________________________________________
TF 2003 ONWARDS
- Behind driver side of facia, fuse for alternator
MINI BLADE FUSE COLORS
PASSENGER COMPARTMENT FUSE BOX
(RHD is shown, while LHD is similar)
All relays in passenger compartment fuse box for MG TF 2003 onwards are the same part number YWB000440:
EM-CVT FUSE
ALTERNATOR FUSE
ADDITIONAL RELAYS
made By Roverlike
