Rover 200 & 25 / MG ZR / SW: Fuses, Relays, ECUs
Voor een 1995 -- Rover 200 mk3 ("bubble") :
Windows, aircon and rear wiper
Engine bay
Engine Bay Fusebox
-Link--Rating--Function
--1----40 amp--Ignition switch A
--2----40 amp--Ignition switch B
--3----40 amp--HRW/sunroof/window lift
--4----40 amp--Lights
--5----40 amp--Engine management
--6----80 amp--Main fuse
-Fuse--Rating--Function
--1----15 amp--Central Door Locking
--2----15 amp--Hazards
--3----15 amp--MFU/horn
--4----20 amp--Radiator fan
--5----15 amp--Engine management
--6----20 amp--Air con
--7----20 amp--Heater motor
Airbag
Pasenger compartment
Passanger Compartment Fusebox
--1----10 amp--Indicators, dim-dip, instruments
--2----10 amp--Antilock brakes
--3----10 amp--Clock, radio, interior light
--4----15 amp--Headlight - right main
--5----15 amp--Headlight - left main
--6----30 amp--Sunroof
--7-----5 amp--SRS
--8----10 amp--Tail light - left
--9----10 amp--Rear fog guard/MFU
-10----10 amp--Headlight - left dipped
-11----10 amp--Headlight - right dipped
-12----15 amp--Tail light - right
-13----15 amp--Wash/wipe - front
-14----10 amp--Engine management
-15----15 amp--Cooling fan, wash/wipe - rear
-16----10 amp--Reverse, stop lights
-17----10 amp--Radio, clock, MFU
-18----10 amp--Door mirrors, heater motor
-19----10 amp--Cooling fan
-20----10 amp--Engine crank
-21----20 amp--Window - driver
-22----20 amp--Window - passenger
-23----25 amp--Heated Rear Window
-24----10 amp--Dim-dip
-25----10 amp--Illumination - daylight running
-26----20 amp--Power wash
-27----10 amp--Heated seat - passenger
-28----10 amp--Heated seat - driver
-29----10 amp--daylight running
-30---- - - ---Not used
-31----20 amp--Fog lamp - front
Source : http://forums.mg-rover.org/mg-zr-rover- ... us-809289/" onclick="window.open(this.href);return false;
made By Roverlike
Re: Rover 200 & 25 / MG ZR / SW: Fuses, Relays, ECUs
Voor een 2000 -- Rover 25 / MG ZR mk1 :
Rear wiper
Engine bay
Engine Bay Fusebox
Relays (R)
1. Fuel pump relay.
2. Starter motor relay.
3. Cooling fan relay.
4. Main relay.
5. Blower motor relay.
6. Front fog lamp relay.
7. A/C compressor clutch relay.
-Link--Rating--Vehicle---Function
--FL1--150 A----All------Alternator, engine management relay.
--FL2---40 A----All------Ignition switch.
--FL3---40 A----All------Ignition switch.
--FL4---40 A----All------Fuse 3, fuse 6, and fuse 9 of the passenger compartment fuse box.
-------------------------Fuse 23, 24 and 31 of the passenger compartment satellite fuse box.
-------------------------Window lift relay.
--FL5---40 A-------------Not used.
--FL6---80 A---L Series--Glow plug relay.
--FL7---40 A----All------Starter relay, fuse 20 of the passenger compartment satellite fuse box.
--FL8---20 A----All------Condenser fan, cooling fan relay, fuel pump relay, cooling fan motor.
--FL9---40 A----All------Lighting switch, daylight running unit, daylight running relay.
-FL10---30 A----All------Blower relay, cigar lighter relay.
-FL11---40 A----All------Cooling fan relay.
-FL12---40 A----All------ABS ECU.
-Fuse--Rating--Vehicle---Function
---F1---10 A---L Series--EGR Solenoid, MAF sensor, HO2S, speed transducer.
---F1---10 A---K Series--Purge control valve, HO2S.
---F1---10 A---EM-CVT----Automatic transmission selector, GIU.
---F2---20 A---L Series--Fuel pump, ECM.
---F2---20 A---K Series--Fuel injector No.1, 2, 3 and 4, ECM, valve increase solenoid, valve
-------------------------decrease solenoid, ignition coils 1 and 2.
---F3---10 A---L Series--Glow plug relay.
---F3---10 A---K Series--HO2S, CMP sensor.
---F4---10 A----All------A/C relay, cooling fan relay.
---F5---15 A----All------Anti-theft alarm ECU, alarm sounder relay.
---F6---15 A----All------Front fog lamp relay.
---F7---15 A----All------Hazard warning switch.
---F8---15 A----All------ECM.
---F9---10 A----All------A/C relay.
--F10---20 A---K Series--Fuel cut-off switch.
Passenger compartment
---F1---10 A----All------Hazard warning switch, clock, instrument pack.
---F1---10 A----EM-CVT---Automatic gearbox
---F2---10 A----All------ABS ECU
---F3---10 A----All------Interior lamp, tail door lamp, diagnostic socket, instrument pack,
---------------except----remote radio display, clock, CD player, radio/cassette.
----------------Japan----
---F3---10 A----Japan----Interior lamp, tail door lamp,diagnostic socket, instrument pack,
-----------------only----remote radio display, clock, folding door mirrors, seat belt switch.
---F4---10 A----All------Instrument pack, RH headlamp.
---F5---10 A----All------LH headlamp.
---F6---25 A----All------Sunroof relay.
---F7----5 A----All------SRS DCU.
---F8---10 A----All------Instrument pack, HRW switch, headlamp levelling switch, LH tail
-------------------------lamp, CD player, clock, MFU, glove box lamp, radio/cassette, remote
-------------------------display, front fog lamp switch, LH headlamp.
---F9---10 A----All------MFU.
--F10---10 A----All------LH headlamp.
--F11---10 A----All------RH headlamp.
--F12---10 A----All------RH tail lamp, RH headlamp, RH headlamp levelling motor, number
-------------------------plate lamp.
--F13---15 A----All------Windscreen wiper motor, windscreen wiper switch.
--F14---10 A----All------Cooling fan, ECM, anti-theft alarm ECU, blower motor relay, cigar
-------------------------lighter relay.
--F15---15 A----All------Heated washer jets, rear screen wiper switch, A/C switch pack, rear
-------------------------screen wiper relay, rear screen wiper motor.
--F16---10 A---L Series--Brake pedal switch, reverse lamp switch.
---------------K Series--
----------------manual---
--F16---10 A---K Series--Brake pedal switch, reverse lamp switch.
---------------automatic-
--F16---10 A---K Series--Brake pedal switch, CVT switch.
----------------EM-CVT---
--F17---10 A----All------MFU, radio remote display, radio/cassette, CD player, ICE interface
-------------------------module.
--F18---7.5 A--L Series--Driver door mirror, passenger door mirror, door mirror switch, alternator,
---------------except----folding mirror ECU.
--F18---7.5 A--K Series--Driver door mirror, passenger door mirror, door mirror switch, gearbox
---------------except----secondary speed sensor.
----------------Japan----alternator, folding door mirror ECU.
-----------------Only----
----------------Japan----secondary speed sensor, folding door mirror ECU.
Passanger Compartment Sattelite Fuseboxes
-Fuse--Rating---Vehicle-----Function
--F19-----------------------Not fitted
--F20---10 A----All---------Ignition switch.
--F21---20 A----All---------Window lift ECU, LH front window switch.
--F22---20 A----All---------RH front window switch.
--F23---25 A----All---------HRW relay.
--F24---15 A----All---------MFU.
--F25---10 A--Scandinavian--Daylight running relay.
---------------vehicles-----
-----------------only-------
--F26---20 A--Scandinavian--Power wash relay.
--F27---10 A--Scandinavian--Not used.
--F28---10 A--Scandinavian--Not used.
--F29---10 A--Scandinavian--Daylight running relay.
--F30-----------------------Not fitted
--F31---15 A------Non-------RH rear door mounted window switch, RH rear console mounted
--------------Scandinavian--window switch.
--F32---15 A------Non-------LH rear door mounted window switch, LH rear console mounted
made By Roverlike
Voor een 2004 -- Rover 25 / MG ZR mk2 :
Rear wiper
Engine bay
Engine Bay Fusebox
Relays (R)
1. Fuel pump relay.
4. Main relay.
5. Heated Rear Window (HRW)
--FL2---40 A----All------Ignition switch. Seat relay
--FL4---40 A----All------Fuse 1, fuse 3, fuse 5, fuse 7 and fuse 9 of the passenger compartment
-------------------------fuse box. Window lift relay.
--FL7---40 A----All------Starter relay, fuse 20 of the passenger compartment fuse box.
-FL10---30 A----All------Blower relay, cigar lighter relay, HRW relay.
---F5---25 A----All------Anti-theft alarm ECU, alarm sounder relay.
NOTE: To the best of my knowledge I gave relay layout in passenger compartment fuse box. However I could not test if it is correct with all features present. Because of that, if you find layout is somewhat different, please let me know to be able to adapt it.
Passenger Compartment Fusebox
-Fuse--Rating---Function
---F1---20 A----Horn, Rear Fogs (SCU)
---F2---20 A----Window Lift Rear RH
---F3---10 A----Cigar Lighter/ Accessory Socket
---F4---20 A----Window Lift Rear LH
---F5---10 A----Interior Lamps (incl Loadspace), IPK, Head Unit, Clock
---F6---20 A----Window lift passenger.
---F7---20 A----Window Lift Driver.
---F8---30 A----Sunroof
---F9---20 A----Power wash
--F10---10 A----Headlamp mainbeam RH.
--F11---10 A----DRL interior illumination (Scand)
--F12---10 A----Headlamp mainbeam LH.
--F13---10 A----Front Side Light LH, Tail Lamp LH, Headlamp Level LH, IPK, Glovebox
----------------Lamp, Clock, SCU, Interior Illumination
--F14---10 A----Headlamp Dip RH
--F15---10 A----Front Side Light RH, Tail Lamp RH, Headlamp Level RH, Number Plate Lamp
--F16---10 A----Headlamp Dip LH
--F17---20 A----Blower motor.
--F18---20 A----Seat heat.
--F19---10 A----Radio
--F20---10 A----Crank relay coil.
--F21---15 A----Front wipers.
--F22---10 A----Mirrors, ACG, G/Box secondary speed sensor.
--F23---10 A----ABS ECU.
--F24---10 A----Brake lamps, Reverse lamps.
--F25---10 A----Auto Selector Lamp,Indicators, Clock, IPK, Engine Management System
--F26---15 A----Rear Wiper, Heated Washer Jets, A/C Switch Illum, Heat Seat Relay Coil,
----------------DRL Relay Coils (Scand).
--F27----5 A----SRS DCU.
All relays in passenger compartment fuse box are the same part number YWB000440:
made By Roverlike
