obd codes
obd codes
ik heb mijn nieuwe speeltje eens aangesloten op de MG en 2 codes retour cadeau gekregen.
Ik begrijp er uit dat het iets met de lamda te maken heeft.
Po138. En Po141.
Hoe moet ik dit interpreteren , en waar zoek je dan het juiste onderdeel....wat je evt kan vervangen. :mrgreen:
Theo
Woonplaats: Terwispel
Bericht door Theo »
Vertel eens meer over deze tool,en dit lijkt mij typisch een vraag voor Arjen :D
En wat het is......... ik denk lambda sensor.
OBD II Fault Code
OBD II P0132
OBD II P0138
Fault Code Definition
The Powertrain Computer or PCM has determined that the Oxygen Sensor voltage remained above 900 millivolts for more than two minutes (varies with vehicle make and model) or that the Air Fuel Ratio Sensor remained in a rich-biased mode for too long (varies with vehicle make and model).
OBD II P0132 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 1)
OBD II P0138 Oxygen Sensor Circuit high Voltage (Bank 1 Sensor 2)
Symptoms
Check Engine Light will illuminate
Vehicle may idle or run rough
Decrease in fuel Eeconomy because PCM is in a "limp home" mode
Engine dies
In some unusual cases, there are no adverse conditions noticed by the driver
Common Problems that Trigger the P0132 and P0138 Code
Defective Oxygen Sensor/Air Fuel Ratio Sensor
Defective Oxygen Sensor/Air Fuel Ratio Sensor Heater circuit
High Fuel Pressure
Defective Engine Coolant Temperature Sensor
Defective sensor wiring and/or circuit problem
PCM software needs to be updated
Defective PCM
P0141 OBD-II Trouble Code
Technical Description O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
What does that mean?
This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141. See also: P0135 (Bank 1, Sensor 1).
Symptoms
You will likely notice poor fuel economy the illumination of the Check Engine Light. Causes A code P0141 may mean that one or more of the following has happened: open or short to ground in the wiring harness O2 heater circuit wiring high resistance O2 heater element resistance is high Internal short or open in the heater element Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Possible Solutions
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor) Repair short or open or high resistance in wiring harness or harness connectors
:mrgreen: Het wel wat duidelijker zo.
Een oranje lampje heb ik iig niet,en de rest van.de symptomen ook niet.
:mrgreen: theo ik heb de autel AL 519 aangeschaft
waarmee je behoorlijk wat kan uitlezen.
ik zit nog in de leer en ondek fase ;)
Wel een leuk apparaatje zo te zien.
Wat doen de lambdasensoren in de live data?
Eerst even die p0141 nakijken, die andere code zou een gevolg kunnen zijn van een te koude sensor (of de stekker zit er gewoon niet op, dat kan ook nog). Even meten of er voeding komt op de verwarming, of deze ook aan massa gelegd wordt door ecu en of er ook stroom loopt tijdens de aansturing.
Het gaat om de sensor na de katalysator.
:mrgreen: met de live data ga ik nog aan de slag, ff weinig tijd nu.
ga het wel nakijken ,want nu ben ik nieuwsgierig geworden.
