Gr. Tomas
mg zr-x
416sí señor
ironman
lex
Skytiger
De oude MG ZRX was al te koop.
Althans het blok kon je aanschaffen, en nog steeds.
Blokkie kost excl. clutch and exhaust manifold 8900 pond = een kleine 14000 euro.
Enkel het blok dus...
K4 2-litre
Tuftrided, cross-drilled crankshaft.
Large bore (82.5mm) cylinder liners.
Gas-flowed ultra big valve cylinder head
High lift camshaft
Hydraulic tappets
Modified conrods
Forged 3-ring pistons
Compression ratio – 11.0:1
52mm throttle body
Sequential injection
High flow injectors
4 ignition drives
Lightweight flywheel
C210ps @ 7000rpm and 170 Ibft torque
Cya,
Sky
K4 2-litre
High lift camshaft
Hydraulic tappets
Modified conrods
52mm throttle body
High flow injectors
4 ignition drives
Cya,
Sky
